sky+, scart or s-video?
Discussion in 'Plasma TVs Forum' started by spook, Jun 12, 2004.
  1. spook
    spook
    May 18, 2004
    157
    Hi all, been waiting for a while now for the damn pedestal stand to restock for the 42" viera ;o( now thinking of changing my order to a panny TH-42PWD6.
    just wondering which would give me the better quality pic from a sky+ box, scart or s-video?
    need to know if its worth getting a s-vid module for the panny or just stick with the free scart.
    cheers, spook
  2. Cag
    Cag
    Nov 16, 2003
    235
    Newcastle
    +9
    try geting a good quality scart. The ones you get with sky are OK but a good quality shielded one should make a difference
    Cag
  3. Rasczak
    Rasczak
    Apr 3, 2002
    22,131
    Warwick
    +2,990
    RGB Scart without a shadow of a doubt! You should ensure a good quality cable - QED offer a good compromise between price/performance.
    The QED AV41 is the best choice but does not carry audio should you need that:
    http://www.hificables.co.uk/Product...D/2388/v/6a085aec-8c9a-4d27-b8d9-84e4870d76f7
    ...second best choice is the QED AV21 (which is a normally, high quality Scart that carries audio and video):
    You could spend more but, frankly, the PQ on Sky is not sufficient to make it worthwhile.
  4. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    RGB SCART output from Sky + is better than S-Video. While S-Video is good, RGB is better. However, there are some other ways to connect Sky to a PWD6 which will give even better picture quality. Using the RGB to Plasma VGA unit will give you a very sharp and clean picture.
    All the best,
    Dr John Sim.
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    With the viera RGB scart is the way to go. If you change to a PW6, and why don't you incidentally, you've already got the perfect plasma TV tuner, why do you need another?, The cleanest picture available is with one of Dr. Sims' RGB to VGA converters, though if you also have a AV amp that switches component video, you might prefer to use one of the YUV converters instead, for convenience of use. There is virtually no difference in picture quality between these devices, and both are way superior to the panasonic scart video board.
  6. JiMbOb_74
    JiMbOb_74
    [​IMG] ...and for the best(!)
    Heres mine....
    Panasonic 42" (4)
    Denon 3802 Amp
    Denon 2900 DVD/SACD
    Vibe 12" Stealth (hidden of course)!
    782se Mission Fronts
    78C Centre
    3 X 78 DS rears
    XBOX
