I have a Samsung LE32M51.
With regards to how it makes the picture worse, if for instance I go to the sky menu and highlight a programme, the text becomes more blurry when set to "on". If however I then set the SKy+ box to output PAL instead of RGB, the picture becomes sharper. When the scart control is set to "off", the picture is sharper but if I then set the Sky+ box to either RGB or PAL, the picture is the same. I would however expect the RGB setting to produce a better picture (which is what it did on my old CRT)
Could it be that my TV scart inputs are not RGB enabled even thought the specs say they are. There is no indicator on the TV that says RGB!
Any help would be appreciated!
cheers
