Sky satellite dish
Discussion in 'General TV Discussions Forum' started by The 9th Doctor, Apr 27, 2007.
  1. The 9th Doctor
    The 9th Doctor
    Dec 3, 2003
    54
    I have just moved to a new house who have left there old Satellite box and dish behind. I am thinking about buying a HD TV and I am wondering if I can use the current dish and somthing like the Pace DS810XE set-top box to recive HD TV.
    How do I chcek that the disk is aligned correctly or if I can recive a signal without having to pay for the box first.
    Thanks for your help.
    Trevor
  2. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    yes you can use the sky dish for BBC HD. Thats what i'm currently doing.
  3. stockyvillage
    stockyvillage
    Apr 6, 2006
    1,217
    liverpool
    +91
    Check to see if the old sat box is working first.If so check your sinal strength and quality in the settings by pressing services.then press no 4.then press no 6.That will show you what you asked
  4. The 9th Doctor
    The 9th Doctor
    Dec 3, 2003
    54
    I tried the old box when I first moved in but I could not get a signal out of it. I thought this was becaue I did not have a card, is that assumption not correct ?
  5. stratagem
    stratagem
  6. langbarb
    langbarb
    in order to be reasonable what level of signal strength should I have in % terms? 100% or is 60% enough? and how about signal quality?
  7. dazza74
    dazza74
    Aug 24, 2006
    13,037
    +1,394
    Pretty sure when I nstalled my Pace box on Tuesday I was only getting around 60% and it was perfectly viewable, think I was getting about 80% yesterday and BBC HD was superb last night.
