Originally posted by danny-p
av junky cheers for the link.
BTW i didnt make that ixos rgb scart to 5 rca cable in my garage at home i was reccommended it by the guys at 7oaks where i bought my arcam dv27 dvd player. They said this would work fine with the arcam (which it does) and with your sky+ "Providing it is RGB compatable" (which it is).
Dont get me wrong the cable does work fine in component mode when you leave the s-video connected .... which must be using the s-video a an extra sync or somthing.
Apologies danny-p. It wasn't until I read throught some of the info on the link that I found out about some Panny plasmas accepting RGBS via direct cable connections. That was a new one for me. No offence intended
However, it does still sound like a connection problem. As you say, could be a synch issue.
Could be an idea to post in the Plasma and LCD forum, to try and find a fellow owner who's used the same connections.
Also, if you haven't seen it yet, there is a post in the Progressive Scan forum from someone else having trouble getting RGB through to his plasma. Could be worth a look?
