Sky router
Discussion in 'Sky Broadband' started by kelis901, Apr 6, 2012.
  1. kelis901
    kelis901
    Nov 27, 2011
    4
    Just seen an advertising about Sky any-time plus how you can use your own router :clap: just need some clarification on this matter as i've seen other threads about t&c.
    Any help would be greatful as i would like to use my own router Netgear N600 wireless dual band router. Thanks! :thumbsup:
  2. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,296
    +677
    Cheapest way is to do what i did and run an eithernet cable from your router to the sky box.
    Or if you have an old wireless router lying around use that as a bridge.
    Or pay sky for there wireless box Connect to TV on demand - Sky VOD
  3. SNIPIT
    SNIPIT
    Apr 8, 2012
    838
    46
    Y Drenewydd
    +160
    i accidently got Sky tech involved on exchange issue, they checked my line etc and did not seem to care i had my billion connectd. From what i understand from some Sky forums, they just dont offer the support of others.
  4. tonyrees687
    tonyrees687
    Mar 20, 2006
    2,816
    Iver Heath
    +454
    Sorry for jumping the post But what do you mean by using another router as a bridge and how would you do this.
  5. Grggs9
    Grggs9
    Apr 22, 2011
    26
    4
    You need to extract your username and password from your sky router, just google it. I just connected my billion bipac 7800n to sky. Put this into your preferred router settings in the Wan section and connect.
    Regards.
  6. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,296
    +677
    If you have a spare router connect it up to your pc and disable DCHP and the wireless.Connect via eithernet to your main router and you can then connect other devices ie the sky hd box to the router (bridge/adaptor)
    Or you could do it wireless but ive not tried this.
    How to connect two Routers together
