Sky + & room distribution : Installation required
Discussion in 'Sky Digital TV Forum' started by jasonbosley, Nov 6, 2004.
  1. jasonbosley
    jasonbosley
    Jun 11, 2002
    15
    3
    As above, I'm looking to get Sky+ installed and distributed by loftbox around to four rooms in the house. It's a new build and the TV sockets are already fitted to each room running to a standard junction box in the loft.
    Don't want to watch different channels in each room, just feed sky to each room.
    So I'm thinking, I should get a local installer to fit sky+ running the cables into the loft to fix to the loftbox.
    Can anybody recommend a local satellite installer which would fit a basic room distribution setuo in the Birmingham, area ?
    I could probably have a go myself at the distribution but for the sake of 50 - 100 I'd rather have it setup up right !
    As I understand it RF distrubtion is mono, anyway to distribute but get stereo ?
    Thanks for any replys, great forums by the way !
