sky +(rgb) thru panna e55(component) connected to pw6 component board will it work?
Discussion in 'Plasma TVs' started by SILVERBACK, Jan 3, 2005.
  1. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,814
    71
    birkenhead
    +73
    was wondering if that setup would work as im sure the e55 wouldnt have the needed hardware to the rgb in signal to a component output.so does anyone have this setup ?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    yeap that works fine mate RGB>E55 to component input (or VGA on PW6 as well)
  3. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,814
    71
    birkenhead
    +73
    does it just loop through the rgb or is there a little bit of trickiery involved in the process? must admit i didnt think it would work.i was thinking about going ALL component with my current list of equipment
    sony ns900
    xbox
    e55
    ps2
    sky+
    would this be possible and would the best way be a component switcher going into a JStech vga to component box? i did a search before asking but couldnt see anything that matched.thansk for the info :smashin:
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    do you mean SKY>JS RGB-YUVbox>Component switcher to screen i would go SKY RGB>E55>component switch everything else component to AV switcher (amp) and then to Component input on screen
  5. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,814
    71
    birkenhead
    +73
    i was thinking more
    ns900
    xbox
    ps2
    e55
    sky+>e55 ALL into a component switcher (if there available) and have the switcher go thru a jstech vga to component box.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    switcher is available http://www.av-sales.com/html/avt-5842mx_.html but i dont get where the VGA comes into it..
    its ethier RGB scart to JS RGB>VGA(RGBHV signal) box
    OR
    all component (via whatever) to component board (or in PW6 case to the VGA socket a 3 RCA>15 pin D-sub cable) this is a cable not a converter [think this what you meant]
  7. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,814
    71
    birkenhead
    +73
    sorry was getting confused,yeah thats what i meant the vga socket to 3 rca.
