Sky RGB splutter - help required
Discussion in 'Sky Digital TV Forum' started by nic@highgroundd, Feb 5, 2005.
  1. nic@highgroundd
    nic@highgroundd
    Jan 10, 2005
    182
    +3
    Could anyone shed any light on why Sky is freezing and blocking when switched from normal scart to RGB?
    Using a Viera plasma screen, when plugging Sky into AV1 or AV4 (RGB enabled) the Sky picture stutters and goes blocky (as if a storm was interfering with the external dish). The signal strength is about three quarters which would suggest this is okay and AV2 (none RGB) is fine.
    ... Anyone?
