Sky RGB Question
Discussion in 'Plasma TVs Forum' started by Synchro, Sep 23, 2003.
  1. Synchro
    Synchro
    I have switched my sky digibox to RGB output in the menu setting and its made no difference/change to the picture.
    Is that right ?
    I have a brand new Cambridge Audio scart that was supplied with the screen.
    I also noticed that the signal strength is about 60% and Quality about 70% on the bar chart, again in the setup menu what should I expect to get an improvement picture quality?
    Guys
  2. Darren Blake
    Darren Blake
    Apr 28, 2003
    625
    Norwich, UK.
    +15
    Have you:
    a) Got a SCART lead with the RGB pins wired up?
    b) Set your TV / Plasma / LCD to receive an RGB image?
    RGB still transmits a composite signal for sync. If the answer to either (a) or (b) is no, then your screen will still only be seeing the composite part of the signal.
  3. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,516
    Kent
    +830
    also:
    c) Made sure you are using the "TV" scart on the digibox and not the "VCR" one? (only TV one outputs RGB)
  4. Darren Blake
    Darren Blake
    Apr 28, 2003
    625
    Norwich, UK.
    +15
    I didn't know that...! :)
  5. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    More info on your setup needed, synchro.
  6. Synchro
    Synchro
    Its a very simple setup, sky (not plus) panasonic digibox directly connected to a relisys plasma using a cambridge audio 5m scart. The scart is connected into the TV scart socket on the digibox.
    Using a Pioneer DVD player the picture is great !
  7. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Has your DVD got 2 scarts and is it 1st on the scart chain? If so it may not support rgb pass through. Or do you have more than 1 scart on the plasma, I'm not familiar with it. It's common for not all scarts to be rgb enabled. Try it in the socket whee the dvd gives a good picture. You might have to connect the dvd another way if that's the case, or pass the dvd scart through the stb, that definitely works.
  8. Synchro
    Synchro
    I only have one socket on the DVD so no chain, I manually change the cable over to view DVD's. The plasma only has one socket one the tuner board. It's direct from the Sky box to the plasma.
    My scart lead was supplied with the plasma how can I tell if its RGB wired there is no info on the box although it is of reasonable quality (and cost !)
    many thanks for all the help :)
  9. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Almost all scart devices send the composite (PAL) signal at the same time as RGB, as the display uses the composite signal for timing (synchronization) DVD is such a clean signal it'll always be better than sky, so what the trouble may be is that the plasma needs to be told in it's setup menu to look for an RGB signal on the scart. It's displaying composite off the sync. signal. Your scart lead should be quite thik, a fully wired scart has 21 wires inside, so should be as thick as a finger, or so. Or flat, about 3cm across, like a black Rhodium or similar. Check that menu out, report back!
  10. Synchro
    Synchro
    Thanks MAW,
    The scart has 21pins and shes a thick un :)
    I will try the menus this evening, although I have had a quick look.
    I have a setup menu that gives me options but I can only get a picture when its set to AV1, could there be some kind of sub menu for setting up the AV1 input ?
  11. sam43
    sam43
    Dec 13, 2002
    29
    3
    I would double check the scart cable. I have been having a similar problem with my sky box connecting to TV. Problem was that the scart cable, although it has all 21 pins, was not fully wired inside and so was only carrying a composite signal. It too was a thick cable but don't assume yours is RGB.
    Hope you find your problem soon!
  12. Darren Blake
    Darren Blake
    Apr 28, 2003
    625
    Norwich, UK.
    +15
    You can check the SCART pin assignments here
  13. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Sam, you must have been criminally unlucky, never heard of such a thing! Desperate last resorts to check that. In the setup menu of the plasma, there should be a section on inputs, where under AV1 it might say 'video' ,'pal' or 'composite', which hopefully you can change to 'RGB'. Some screens autosense it, like most TV's, in fact there may be an 'auto' setting for you, which might be best, then you can always see the menus on stuff you plug in, so you can switch the best video on for everything.
