HomeyJay
I would like to control all of the sky signal through my AV amp but to do this I can use either S-video or component. Sky + only has RGB or SVideo right now & going thru the amp but I'd like to use component instead for a better picture. If I get a RGB to component convertor and put that into the AV amp, will the quality be as good or almost as good as using straight RGB ?
I hope this is clear !!
