SKY+ RGB passthrough queries...
Discussion in 'Sky Digital TV Forum' started by McBain, Sep 22, 2003.
  1. McBain
    McBain
    Feb 15, 2001
    178
    Fair Oak
    Hi all,
    As usual, I'm running out of connections. Having previously used a manual SCART switchbox, I;ve recently upgraded my AMP to a 3803 which has component switching. However, even with this I'm still short of an RGB connection ofr PS2 or Gamecube. Basically, my question is this - does the SKY+ (most recent box) support RGB passthrough, and if so how would I get the output of the Gamecube/PS2 displayed?
    Cheers,
    Sam R
    Winchester UK
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Yes it does, and should pass it through when you turn the console on. Should revert to sky when you press a button on the remote.
