Sky+ RGB pass through
Discussion in 'Sky Digital TV Forum' started by Tesla, Jan 4, 2005.
  1. Tesla
    Tesla
    Dec 9, 2003
    936
    Bristol, UK
    +32
    Will passing my XBox RGB signal through my Sky+ (V1) box degrade it at all?
    I could alternatively hook it direct into the 3rd scart socket on my Panny TX28PM12 and the DVD move to AV2 and set to SVideo.
    At the moment I have XBox looped through Sky and DVD direct to TV. All set as RGB. Is this the best setup?
    I imagine that there will be nominal difference with setting it up an alternative way.
  2. jammyb2004
    jammyb2004
    Apr 12, 2004
    1,113
    63
    +113
    the way it is, is fine. to test it run a compatible game at 60hz, if it gives u colour, then the setup is fine and ur getting the best picture u can get.
    if black/white or fuzzy. plug xbox direct into tv. if still black/white or fuzzy then ur still getting the best setup the way it is. if it goes colour directly into tv you'll know for sure.
    jammy
