sky rgb output problem
Discussion in 'Sky Digital TV Forum' started by dingo8yobaby, Jan 3, 2005.
  1. dingo8yobaby
    dingo8yobaby
    Jan 29, 2004
    2,021
    83
    a place that haz no reconz:(
    +294
    when i use my sky box to output a pal signal the picture is fine, but when i switch it to rgb out for a better picture the signal breaks up intermittently especially when changing channels -lease tell me why as i much prefer the rgb picture when it works! thanks in advance.
  2. himpressive
    himpressive
    Sep 28, 2004
    81
    11
    Hemel Hempstead, Hertfordshire
    +7
    Does your TV have an RGB scart input or just normal scart? ;)
  3. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    Sorry to ask the obvious but what does it matter when you're changing channels? I did notice that you said it did when you weren't changing as well.
    Do you have another source (DVD etc) to compare against to pin down fault between Sky/TV. The first thing to do is cahnge the scart as that's the simplest, make sure you get fully wired.
  4. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    Bradford, West Yorkshire.
    +323
    Panasonic digibox?
    A. Dork
  5. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    Good point, there was a problem with Pannies and RGB.
  6. dingo8yobaby
    dingo8yobaby
    Jan 29, 2004
    2,021
    83
    +294
    its definatley an rgb scart input on the tv as i tried it with my dvd player and that worked fine. Also when i flick between pal and rgb theres a massive improvment in pic quality only problem is after a few minutes of watching a channel the pic pixellates and it also happens when changing channels. by the way, its an amstrad box. thanks for the replies, they're much appreciated.
  7. jammyb2004
    jammyb2004
    Apr 12, 2004
    1,113
    63
    +113
    check u haven't a bent pin in the scart cable connecting your box to ur tv. mite be wats causing the problem.
    jammy
