Sky+ RGB on Scart to Panny PHD7 via RGB terminal board
Discussion in 'Sky Digital TV Forum' started by Eye in the sky, Nov 19, 2004.
  1. Eye in the sky
    Eye in the sky
    Nov 19, 2004
    83
    Hi there,
    I will be having a Panny PHD7 soon. It will come with the RGB video terminal board TY-42TM6Z which has the RGB RCA + Audio LR connectors. I also have a Sky+ digibox.
    To connect my Sky+ digibox to my PHD7 RGB terminal board, I am thinking of using the QED AV19 Scart to 6-RCA phono cable (RGB-RCA + Composite-SYNC RCA + Audio LR-RCA). Meaning connection the QED AV19 Scart from the SKY+ digibox to the PHD7's RGB terminal board using the three RGB RCA connectors only, leaving the Composite-SYNC RCA unconnected.
    The Panny RGB terminal board requires the Sync to be on G, I guess technically its RGsB. It has only the RGB RCA (three)+ Audio LR connectors and NO composite RCA!
    My question to all is will this connection setup work? IE would I get a good/stable picture from my SKY+ on my PHD7? Most imnportantly, does the SKY+ digibox output RGB wth Sync on G???
    SKY+>RGB <--QED AV19 Scart to 6 Phono--> PHD7>RGB video terminal board
    with SYNC on G.
    Pls help.
    Cheers.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Better off asking in the Plasma forum, the retailers who contribute and more experienced users will probably have the answers for you:)
    I personally would consider the RGB to VGA convertor from JS Tech, well respected solution and reported to give very good picture quality.
    Ah, I see you've already got the answers from the guys over in plasma:)
  3. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    Either that or simply use a scart terminal board. I don't understand why you are trying your method.
  4. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    SCART board is ok, but you can do better. And the way I look at it, if you're spending as much as you have to for a good quality screen, you're looking for the best.
    All the best,
    Dr John Sim.
  5. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    Would have to agree with Starburst,thats the way i set mine up.
