Sky RF2 for Bedroom Viewing
Discussion in 'Sky Digital TV Forum' started by Kit85, Feb 18, 2013.
  1. Kit85
    Kit85
    Feb 12, 2009
    178
    London
    +5
    Hi Guys,
    Currently, I have an external aerial connected to the 'Input' of a generic 6 way amplifier which feeds the signal to four rooms. As I have no need for Freeview in the living room where the sky box is I thought I could connect the coax to the RF2 and then connect the other end to the second 'Input' on the amplifier.
    Will this allow me to have Freview and Sky in each room and will it enable me to use a magic eye in the bedroom? I did do I search which led me to this setup but my main concern was any issues regarding the RF2 power and the amplifier.
    Any help is greatly appreciated.
  2. logiciel
    logiciel
    Feb 2, 2008
    53,166
    UK
    +5,789
    Hi. That will get the channel one way and may get remote control back the other.
  3. winston2010
    winston2010
    Jun 28, 2010
    1,922
    London
    +201
    If an amplifier has 2 inputs they won't both be for UHF. The second input is probably for VHF, so no it won't work.
  4. Kit85
    Kit85
    Feb 12, 2009
    178
    London
    +5
    Logiciel - thanks for the input. Is there any way I can ensure the remote signal is sent back to the Sky box?
    You are correct! Can I use a combiner at the UHF input to allow both the Sky and aeriel signal to be fed to the other rooms?
  5. logiciel
    logiciel
    Feb 2, 2008
    53,166
    UK
    +5,789
    Yes, just join them with a standard Y-combiner and make the output from that the input to the distributor.
    Whether the remote gets back the other way depends on several factors and you'd only find out when you try it.
  6. Kit85
    Kit85
    Feb 12, 2009
    178
    London
    +5
    Thanks for the response.
    One more question - I already have a magic eye connected to the RF2 as the Sky box is hidden in an AV unit. Can I run the coax cable from the magic eye unit or should I use a Y- combiner for this too?
  7. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    You cannot use Eyes in series, you will need a splitter.
  8. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
  9. logiciel
    logiciel
    Feb 2, 2008
    53,166
    UK
    +5,789
    That's not quite clear but the reply is probaby no. A wireless IR extender would be a more reliable method.
  10. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Another "two heads"? :confused:
  11. Kit85
    Kit85
    Feb 12, 2009
    178
    London
    +5
    Thanks for all the replies.
    I will try and get the picture working before worrying about the additional magic eye for upstairs. I'll report back once done although more likely it will be for more advice :laugh:
  12. logiciel
    logiciel
    Feb 2, 2008
    53,166
    UK
    +5,789
    Yours was clearer than mine about what the setup is.:)
  13. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    You'll just have to give up those pangalactic gargleblasters! :laugh:
