We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Sky + RF out is in widescreen
Discussion in 'Sky Digital TV Forum' started by bigfecker, Nov 4, 2005.
  1. bigfecker
    bigfecker
    Jul 23, 2003
    591
    +27
    Hello :hiya:
    My main TV is widescreen, I have then used the RF out to connect to a second TV which is 4:3 therefore the picture is all squashed, can I output the RF at 4:3 and the scart at 16:9 - if so how?
  2. The Fulwell
    The Fulwell
    Jul 1, 2005
    107
    Sunderland
    +12
    You certainly can.
    Go to Services, then in the 'Picture' settings, there's a function where you can alter the settings for your second TV.
  3. bigfecker
    bigfecker
    Jul 23, 2003
    591
    +27
    fantastic, I'll take a look later :)
  4. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    You can't do this at the same time! If you have your main set as 16:9 and the other at 4:3 if you change the channel or anything on the 4:3 set then the 16:9 set will revert to 4:3.
    It is all ok as long as you do not have both on at the same time.
  5. bigfecker
    bigfecker
    Jul 23, 2003
    591
    +27
    I set it but the picture is still 16:9, seems whatever the main output is is what I get on my second TV.
  6. shoestring25
    shoestring25
    Feb 2, 2003
    4,669
    essex
    +985
    this fuction never worked. instead of them creating new fuctions for sky + why dont they just get it to work properly in the first place
  7. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    24,017
    2
    The Fylde Coast
    +14,045
    The 4:3 has worked on the RF2 on Sky+ for my portable TV in the kitchen. :shrug:
  8. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    That function was never intended to provide a 16:9 output on one connection and a 4:3 on another.
    It is purely for users of the TVlink connected to a TV with a different ratio to the primary display, it then allows automatic ratio switching depending upon the location the digibox is being controlled from.
  9. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    SKY hardware only have a single video stage, the picture ratio will be the same on all the video outputs.
    The Second Location setting is only useful if you are using a TVlink, the ratio then automatically changes depending upon which location the digibox receives the remote commands from.
  10. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +272
    It's a pity that people can't read the manual before they launch attacks on Sky's software.
  11. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    24,017
    2
    The Fylde Coast
    +14,045
    What's a manual? ;)
    Actually it looks as though the box does everything it says on the tin.
    Coz the box changes ratio depending where it gets its signal, I hadn't realised why I was seeing different ratios on the tv's when I moved from one room to another. We live and learn. Thank you.
  12. bigfecker
    bigfecker
    Jul 23, 2003
    591
    +27
    So if I have a TV Link on the second TV it should then be 4:3 :rolleyes:
  13. Scapegoat
    Scapegoat
    Nov 19, 2004
    2,638
    Leeds
    +137
    Yes - you need a sky-link on the RF2 outlet.
    If you have a 16:9 TV connected to the Scart outlet and a 4:3 TV connected to the RF2 outlet, then go into the Picture settings and set up the screen ratios accordingly.
    As soon as you press a button on the remote pointing at the sky-link e.g. press Select to get the banner to appear, the screen ratio will switch to 4:3 or 4:3L etc.
    If you press a button on the remote pointing directly at the Sky box it will revert the ratio to 16:9.
    If you have both TVs on at the same time, then one of them will always display the wrong ratio.
