Sky + Reset
Discussion in 'Sky Digital TV Forum' started by asimm, Feb 5, 2005.
  1. asimm
    asimm
    Aug 3, 2000
    1,516
    48
    +75
    There is a way to reset or re-format the box. Have done a search on these forums but can't find anything - might be using the wrong words. Anybody know how to do this? I don't want to call Sky again.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Reset is just switch off at the mains (when the box is in standby with the drive spun down and not recording).
    As for reformat, well this method will clean the drive and reset it to it's original state.
    On the remote...
    Services
    4
    Select
    Then choose FULL SYSTEM RESET
    This will wipe the hard drive and all series link info.
    You do this at your own risk.
