Sky remote
Discussion in 'Home Cinema Control & Remote Controls' started by milgo, Jan 31, 2003.
  1. milgo
    milgo
    My sky remote used to control the volume & channel selection on my sony TV..................I now have a new sony TV KV32FX66 and the remote no longer controls those functions. Can the remote be programmed to the new TV.?
  2. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    IIRC the number to input is 0000.
  3. milgo
    milgo
    Thanks very much for a prompt reply but as this is something that i've never had to do before I'm not entirly sure what it is that I have to do with that code?
  4. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    Milgo if you have your digibox manual it has all the instructions in there to program your remote if you have not got one or you dont get a reply from post before tonight I'll post the code when I get in:smashin:
  5. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    Lynx is spot on the code to input is 0000:clap:
  6. milgo
    milgo
    Hi Guys could not find my user manual are you able to give me the steps that i need to follow to do this?
  7. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    Press TV on the remote
    Hold down Red & select for a few seconds ( red light will blink )
    Press TV on remote again
    Key in code (000)
    Try the controls
    If the above does not work i'll post the complete instructions later.
  8. milgo
    milgo
    Great stuff, working a treat now. Thanks.
  9. muppetmick
    muppetmick
    Nov 11, 2002
    84
    over the rainbow-way up high!
    Just bought a new Sony television and the code still works!:thumbsup:
  10. ghorricks
    ghorricks
    Jun 20, 2005
    Worked for me... Cheers!
  11. safegeezer
    safegeezer
    Dec 4, 2004
    27
    3
    Worked for me too thanks a million for the tip, cheers!
