SKY remote
Discussion in 'Sky Digital TV Forum' started by Biggles, Aug 19, 2002.
  1. Biggles
    Biggles
    Help!
    I've got SKY and I want to control it using another controller but I'm having trouble.
    On my list of equipment on the remote it does't list the SKY system.
    Any idea's as to what I could try?
    The sky box is a Pace and this isn't on the list either.
  2. ned
    ned
    hi ya i control all my stuff including a sony sky box using a cambridge m 1 + fron richer sounds
  3. lechacal
    lechacal
    Aug 13, 2001
    711
    Cheltenham
    +66
    What kind of remote do you have?
    If your Digibox isn't listed and your remote isn't capable of 'learning' then you might not be able to control your Digibox with the remote. If you have a learning remote though it should pick up the codes, unlike Telewest/NTL remote codes which can't be learnt by most learning remotes.
