Sky Remote
Discussion in 'Sky Digital TV Forum' started by eel, Mar 28, 2002.
  1. eel
    eel
    I have noticed when using my sky remote to access options under Sky Sports Extra and when navigating through different options on other interactive services my remote seems very sluggish. Sometimes it refuses to move at all and needs several presses before it actually wakes up. i have changed the batteries, but no luck. Does anyone have any suggestions?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Are you sure it's the remote and not just your digibox taking it's time to process all the extra data required for the "interactive" functions?
