Sky+ Remote
Discussion in 'Sky Digital TV Forum' started by Fallguy, Dec 8, 2003.
  1. Fallguy
    Fallguy
    Just had Sky+ installed and am now looking at two defunct remotes. Read on an earlier thread that you can reprog as fol:
    Press TV and release
    Hold select and blue button down together until LED on handset flashes twice and release
    Press No 2 and release
    Press select
    Ok it works but all I can do is switch channels on the + / - key...since I need to use it in the bedroom I at least need to be able to switch the system off. Any suggestions on how to increase the functionality??
  2. Techno
    Techno
    Nov 20, 2003
    312
    Sell the two remotes on Ebay and buy a new SKY+ remote from Sky for £20 delivered, probably won;t cost you anything!
  3. DaveP
    DaveP
    Why bother, it still keeps the disk spinning, it only powers down the video display circuit.
    Dave
  4. Fallguy
    Fallguy
    Thanks guys, think i'll try the ebay option.:D
