Sky remote won't control tv
Discussion in 'Sky Digital TV Forum' started by magiceye, Dec 5, 2004.
  1. magiceye
    magiceye
    I have a LG RI-32CZ10RX and I've tried all the codes LG supply but to no avail
  2. timanfiya
    timanfiya
    Have you tried the blink method?
    Press tv button and face towards tv.
    Hold red button and select until led flashes twice.
    press 990
    press button 1 and watch how many times the led blinks (this is your first number - note, if the led does not flash your fist no. is 0)
    press number 2 and watch how many times it blinks
    Do the same for 3rd and 4th (if your remote has a four digit code- it may only be three- if it does not flash on four assume either you only have a three digit or your fourth number is 0)
    Give it a try, although I have seen someone do it get the code but it still didn't work the tv. Works on mine though and picks up the right code.
    Good luck :thumbsup:
