SKY+ remote wont control my TV
Discussion in 'Sky Digital TV Forum' started by jtorry, Oct 8, 2003.
  1. jtorry
    jtorry
    Nov 8, 2001
    522
    I got sky+ today and I think its great but I have tried all the codes and I still can't get the remote to work with my thomson TV. I have read that the latest remotes don't work with some thomson sets. Its a right pain having to use the tv remote to turn up the volume. My original sky remote workes the tv fine. So does anyone know of any codes that I can try that they have working or anywhere I can buy an original remote. Or would anyone swap a 1st release remote (good condition) with my nice new one.
  2. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Try one of these........
    Thomson 0771,
    363,315,427,137,361,224,226,327,371,065,518,596,377,
    653,233,499,588
  3. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,897
    Is ther a site where they list the codes for your sky to work your tvs?Iwant my sky+ to turn my plasma on.
  4. jtorry
    jtorry
    Nov 8, 2001
    522
    Johndm: Thanks but I have tried all those codes and the best I get is buttons doing something but not what they should. No volume though.
  5. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    have a look here..........
    www.digitalspy.co.uk/article/ds11383.html
  6. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Thomson 24" Widescreen TV (Model No 24WK25US)
    The Problem: There are a number of functions on the Thomson TV remote control that are not accessible from the Sky remote control, even after correctly entering the three digit code for the TV into the sky remote (653). The most irritating of these is that there is no facility to exit teletext mode, which means you have to resort to the exit teletext button on the remote that came with the TV. So, using the following instructions, you can programme your sky remote to carry out all the functions on the Thomson tv remote:
    1. Setting Overall TV Code. Press TV. Press and hold select & red together until light blinks twice. Enter Thomson TV code 653. If accepted remote will blink twice.
    2. Setting Special Key Magic Codes for Thomson TV. Press TV. Press and hold select and yellow keys until light blinks twice. Enter 994. Press Select. Enter Key Magic Code in following table, followed by button to assign.
    Button on Thomson TV Remote
    Key Magic Code
    Button Assigned on Sky Digital Remote
    Up Arrow
    652
    Up Arrow
    Down Arrow
    588
    Down Arrow
    Left Arrow
    491
    Left Arrow
    Right Arrow
    267
    Right Arrow
    OK Button
    300
    i (information) button
    Exit (Text Off)
    234
    Backup
    Menu
    459
    AV1, AV2 & AV3 Selector
    430
    Channel down (ch -)
    So for example, to programme the 'up arrow' on the Sky Digital remote with the same functions as the up arrow on the Thomson remote, press tv, press and hold select and yellow keys until light blinks twice, enter 994, press select, enter 652, finally press the 'up arrow' on the sky remote
  7. jtorry
    jtorry
    Nov 8, 2001
    522
    thanks for that. Is there anywhere I can get the codes for all buttons like volume and power/standby?
