sky+ remote/tv eye problem.
F
Fernsehman
You imply by "always" that you get it working again. How?
K
KANU25
I've got a simlar problem - I think it maybe to do with the weather!(strange I know) - but when its really cold(like during the night\early morning) it won't work
STOWITBELOW
My link went intermitant, initialy similar sort of problem but the other way around - it wouldn't work at night! It was solved by a box swap )-: sorry. I had brought my link down & plugged it straight in the back of the box, as the LED on the link wasn't on when it wasn't working. I had a spare & tried that but it wouldn't work either so I knew it was the box. Incidentaly, when the engineer called of course it was working. However whilst 'testing' he said it had gone off (I was making a brew) & said he'd swap the box. Who says they just give bad service.
RobbieD
If it only works in the evening, but not in the morning/day, could it be that daylight is affecting the eye? Is it near a window?
Maybe try moving it to a slightly darker position.
S
Stephen2_4_6_8
Have you considered/tried changing the remote controls batteries ?
I have seen my remote stop working. If you leave it a while there is enough power coming out of the batteries to flick a while before they run out again.
STOWITBELOW
Just to reiterate, a) is the led on on the link (where it plugs into the RF socket) when its not working, b) does the remote with the link work the box. If not a) then try the link directly in the box, ruling out or identifying the cable at fault. You could always try another link, but in my experience they're pretty reliable. If not b) then its likely to be the mote (does another one work the box or link) It's just if Sky come out & it's a faulty link they've not recently installed they'll probably bill you.
Similar threads
Podcast: TCL C815 TV, Denon & Huawei wireless speaker reviews, New Sony 4K PJ's and more
