sky+ remote set up
Discussion in 'Sky Digital TV Forum' started by scoobydude, May 29, 2005.
  1. scoobydude
    scoobydude
    Jul 7, 2004
    40
    11
    Hi all is there any way to set the sky remote so that if I press "0" it will take me stright through to the program planner.
    Thanks scoobydude :lease:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Nope.
    With the new radio EPG number update the "0" button will be used for the 4 digit number entry.
    If you really want more control or a one button solution then perhaps a Kameleon/Universal remote is the answer.
