sky+ remote set-up with LG42LD450
Discussion in 'Sky Digital TV Forum' started by chris4652009, Nov 27, 2010.
  1. chris4652009
    chris4652009
    Mar 1, 2009
    1,267
    +328
    can somebody please talk me through the process? :blush:
    I have just set-up my new TV but cant get the Sky+ remote to operate the TV
    :confused:
    thank you in advance
    this is the process I followed
    1. Select any channel on the TV.
    2. Point your Sky+ remote control away from the TV and press the tv button.
    3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
    4. Input the 4 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
    5. Point the Sky+ remote control at the TV and try the volume button.
  2. chris4652009
    chris4652009
    Mar 1, 2009
    1,267
    +328
    I have tried codes
    1206
    0056
    0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851
  3. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
  4. chris4652009
    chris4652009
    Mar 1, 2009
    1,267
    +328
    thanks Tried that just now, but my model isn't listed :(
    LG42LD450
  5. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
  6. chris4652009
    chris4652009
    Mar 1, 2009
    1,267
    +328
    thanks...1206 was the one it threw out when I did a google for my make and model with Rev8 remote
    have just tried the lot^^^^ alas none of them will operate the volume controls :(
  7. logiciel
    logiciel
    Feb 2, 2008
    53,137
    UK
    +5,777
    Time for a universal remote - much better anyway. :D
  8. robocat
    robocat
    Dec 27, 2010
    4
    1206 worked for me
  9. Miss Chief
    Miss Chief
    Jun 12, 2007
    7,823
    +1,187
    I suspect you'll need a version 8 RCU for 1206 to control your TV. Check the version inside the battery cover.
