Sky Remote record on Nokia N73
Discussion in 'Mobile Phones Forum' started by ParisV, Dec 19, 2006.
Tags:
  1. ParisV
    ParisV
    Mar 17, 2006
    283
    +12
    I used to use remote record on my n70. I've just upgraded to the N73 but the software from sky does not work on it. I have looked in a few forums and they have said that this might work:
    http://mobile.sky.com/SBM/SonyE_novid/SkyMobile_SonyWithoutTv.jar
    Trouble is this hasn't! I put in my username first, then when i try to put in a password it goes back to the menu screen. Same if i try the other way round.
    Has anyone go this working with their Nokia n73??
  2. cracker
    cracker
    Sep 4, 2005
    2,055
    +246
    as i recall you need to press "down" or "left" (on the d-pad) or something similar before you can enter your password
    its just a programming glitch in the software which makes it close accidentally if you dont do this
  3. ParisV
    ParisV
    Mar 17, 2006
    283
    +12
    I've found the answer....
    Using the file from http://mobile.sky.com/SBM/SonyE_nov...nyWithoutTv.jar
    I entered the username, pressed ok.
    Selected password but entered nothing, pressed ok.
    Selected password again, entered password, pressed ok.
    Selected Login
    And after a couple of seconds it works.
  4. Johnny Utah
    Johnny Utah
    Nov 25, 2006
    72
    11
    he's right, watch for the cursor blinking, if there is no cursor inside then you need to press up or down respectively to move the cursor in to the box! if there is no blinking cursor when you press a button it will close!
