Sky+ Remote & PX60
Discussion in 'Plasma TVs Forum' started by Scholesy, Dec 19, 2006.
  1. Scholesy
    Scholesy
    Apr 12, 2006
    108
    Manchester
    +9
    Does anyone know how to program the Sky+ remote to control the volume/channel change on the PX60?, Ive had a look around but can't find any info.
    Ta.
  2. Cheekster
    Cheekster
    Mar 10, 2002
    1,162
    63
    Oxfordshire
    +192
    This is from my Sky HD manual (I also have a PX60):
    Turn on both your TV and your Sky+ box and press TV on your remote
    Hold down select and the red key together until the red light on your remote control blinks twice (this is after about two seconds)
    Press TV again
    Key in 0051
    The light on the remote control blinks twice
    Press standby on your remote control
    If you TV switches off, press select. The light on your remote should blink twice
    If your TV does not switch off, press TV then press standby
    Repeat the sequence of pressing TV then standby until the TV switches off, then press select
    Cheekster.
  3. Scholesy
    Scholesy
    Apr 12, 2006
    108
    Manchester
    +9
    Excellent!!, Thanks mate, worked a treat.
  4. Cheekster
    Cheekster
    Mar 10, 2002
    1,162
    63
    Oxfordshire
    +192
    Glad to have been of help.
    Hit the "Thanks" button, that's what it's for! ;)
    Cheekster.
  5. Scholesy
    Scholesy
    Apr 12, 2006
    108
    Manchester
    +9
    Oops, never even noticed it before mate.
  6. Sampson
    Sampson
    Oct 17, 2006
    210
    Plymouth
    +16
    Not got my Px60 or sky yet, but is it possible to set the sky remote to have the power button control the tv but the volume to control a seperate AV amp? I expect that is too much to ask of a simple sky control, but be lovely if it is possible.
  7. Cheekster
    Cheekster
    Mar 10, 2002
    1,162
    63
    Oxfordshire
    +192
    Pretty sure it's not possible simply because by programming the Sky remote to control your brand of TV, it's automatically set to control channel up/down, volume up/down and standby of just TV.
    Cheekster.
