Sky remote programming
Discussion in 'Sky Digital TV Forum' started by Taz, Aug 29, 2003.
  1. Taz
    Taz
    Hi all, can someone give me the code and instructions for programming my sky remote to operate a Panasonic TV.
    :smashin:
  2. Johndm
    Johndm
    Jan 25, 2003
    1,816
    Bedford UK
    +57
    The Panny code is, 0051, but instructions as follows:-
    1. turn tv on
    2. press tv on sky remote
    3. hold down red and select until remote led blinks twice
    4. for panasonic key 678
    5. led on remote blinks twice
    6. press on/off on remote, telly should go into standby
    sorted!!..:clap:
  3. Taz
    Taz
    Thanks, but it didnt work! :confused:
    Is there another code for pannys?
    :smashin:
  4. Johndm
    Johndm
    Jan 25, 2003
    1,816
    Bedford UK
    +57
    Did you try both codes? Think mine worked with the 678 (Panny digibox though) Maybe its the 0051 for you? If I remember, you need to key the code pretty quickly after the pressing of select and red on the remote..
    Its easier to see if it works by using the volume control on the remote. It took me a couple of attempts to get it right!!
  5. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    All the codes are listed in the back of your digibox manual if you still have it.
  6. Taz
    Taz
    Thats the problem Lex, I haven't got it.
  7. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    I didn't think you would still have it, but I thought I'd mention it anyway! :)
    I can find my manual out if you still can't get it working. Did Johndm's codes not work?
  8. Johndm
    Johndm
    Jan 25, 2003
    1,816
    Bedford UK
    +57
    Taken from digitalspy.co.uk
    Panasonic 0051 is the four digit brand code
    And these are three digit set codes
    678, 254, 278, 154, 242, 368, 191, 302, 128, 544, 241, 065, 395, 379, 389, 103, 576
    Gotta be one of those eh??
  9. Taz
    Taz
    Thanks, I'll give them a go :smashin:
  10. Taz
    Taz
    :clap:
    254 was the code. Thanks very much.
    :smashin:
  11. Johndm
    Johndm
    Jan 25, 2003
    1,816
    Bedford UK
    +57
    :smashin: :smashin: :smashin:
