Sky+ remote problems
Discussion in 'Sky Digital TV Forum' started by mark raeburn, Oct 21, 2004.
  1. mark raeburn
    mark raeburn
    Nov 14, 2002
    413
    +19
    I have just had my Amstrad Sky+ box replaced beacuse the picture quality was awful, that's now sorted with the new box however the remote control doesn't seem to work very well. Sometimes the remote fails especially if I'm pushing the "curser up" button to scroll through the EPG while watching a programme.
    Also If I use my Philips wireless TV link this fails even more regulary, and can be very difficult to even change channel.
    Anyone experienced problems with the remote working properly on the Amstrad, I'm certain that the last box that I had worked fine.
    I have tried turning off the video sender and all my other AV kit but this hasn't helped. The only other thing I can think of is that I have a Panny plasma screen andwondered whether this could this be interfering with it?
    Mark
  2. Fernsehman
    Fernsehman
  3. Corkonian
    Corkonian
    Jan 20, 2004
    Mark, I'm haveing a similar problem with a Pace V2 box.
    When I'm trying to use the remote even only a few feet from the box you have to press the button 2 or 3 times for anything to happen.
    The red remote light on the box doesn't light up on the failed attempts.
    Here's the weird thing: it works fine when I'm using it through the Powermid from upstairs??!!
    Is it the box or the remote that's at fault?
