SKY+ Remote problem
Discussion in 'Sky Digital TV Forum' started by deman77, Dec 8, 2003.
  1. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
    I use my SKY remote to change aspect ration on my tv and to change the inputs, but after about 2 months it started blanking out the picture (goes black) when I press 'tv' button. When I press SKY again it works fine.
    Does anyone know how to get it back to normal?
  2. ancientgeek
    ancientgeek
    When you press TV, the video output stops, and your TV may automatically switch to input from its internal tuner or some other input with a video signal. If not, then the screen will go black when you press TV. Can't imagine why yours was ever different. What it does now is what is supposed to happen.
  3. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
    my screen is a pwd6 plasma, which has no tuner.
    I thought it switched the inputs but this is not the case. Could it be something to do with scart control in SKY box?
  4. Fernsehman
    Fernsehman
    In 99% of cases reported to Sky where something "worked before, but doesn't work now" it's a loose Scart plug (or similar cause).
    Fman
  5. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
    TVman, thanks for your advice but my scart is QED and it needs a bulldozer to pull it out when I need to. There is more chance of SKY scart socket coming loose.
    switched off scart control in picutre settings and the problem has cleared.
    While I was looking for a solution I found a way to control my amp with SKY+ remote as well. Now I use it to do the following:
    - all sky+ functions
    - TV on/off, ascpect ratio, source select
    - amp on/off, volume up/down, mute, select source.
    This is pretty much all functions I use for my normal viewing. Still have to use the DVD remote, but that's only 5% of my viewing time.
  6. prycop
    prycop
    How did you do this - i want my SKY+ remote to control amp volume +/-
    Thanks for any info
  7. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
  8. prycop
    prycop
    Thanks:clap:
