Sky Remote Now Working With Video Sender!
Discussion in 'Sky Digital TV Forum' started by himpressive, Oct 29, 2004.
  1. himpressive
    himpressive
    Sep 28, 2004
    82
    11
    Hemel Hempstead, Hertfordshire
    +7
    Hi guys,
    I dont understand how/why this works, but I know it works :D
    I had a video sender that worked well with my old sky box, but stopped working when I got sky+, as far as changing channels from my secondary TV was concerned.
    The other day, I discovered I could actually change channels from my second tv, anytime someone stood 2 feet or less in front of the sky+ box.
    I worked out that an object carefully located could do the same trick; so I put a 6" x 3" booklet (about the thickness of the sky magazine) in front of the IR hole (covering both the IR and the mouse), and presto, it worked! :clap:
    Can anyone pls try this out and see if it works for you too?
