Sky+ remote not working properly in second location
Discussion in 'Sky Digital TV Forum' started by chedmaster, Oct 18, 2005.
  1. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    I have the usual eye config, except instead of using RF for pic/sound i use s-vid and stereo through scart to the second room. this worked fine for ages, both tvs are 16:9 so no aspect probs etc, however since that ******* software update, when i hold any button on the remote in the second room, it works for about 2 secs then stops. so i try to go "up" from 101 to say 130, and it will stall at 103, 106, 107 etc etc. very annoying, i have to let go of the button and re-press it. I have tried turning box off/on at plug, switching remotes and nought works.
    Is there a reset i can do without losing everything? will a software update (forced) lose progs (if not is there any risk at all?).
    I havent had any of the other probs on here, just this one.
    Ta everyone.
