Sky remote - how to skip to start/end of recording
Discussion in 'Sky Digital TV Forum' started by derdle, Mar 3, 2013.
  1. derdle
    derdle
    Jan 3, 2010
    14
    Hertford
    Does anyone know which keys need to be pressed to make a programme skip to either the start or end of a recording?
    When we are either using fast forward or rewind, my partner manages to press a certain combination of keys and the recording skips to either the start or the end of the programme - very annoying. Does anyone know what buttons are being pressed?
  2. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    Pressing and holding the "rewind" and "Fast forward" buttons will take you to the start and end respectively of recordings. Get your partner to take their finger off after pressing the buttons - if you want to increase the speed of rewind or fast forward then merely press repeatedly but do not hold the buttons down.
  3. derdle
    derdle
    Jan 3, 2010
    14
    Hertford
    So simple when you know how. Thanks for the speedy response!
