My sky+ remote won't work. It has new batteries, the red light comes on when you press a button but there is no red light on the box. Does anyoune no how to fix it or do i need a new control?
Possibly requires the remote code re-entering, there's also a reset procedure which at the moment I can't remember what it is, did you let the old batteries go flat?
Sounds like the IR receiver on the box has had it. Can you try your remote on someone elses box just to be certain.
neilmcl, there is no need to do anything to a remote to get it to work a box, only for a TV.
