Sky+ Remote Control Problem!
Discussion in 'Sky Digital TV Forum' started by himpressive, May 16, 2005.
  1. himpressive
    himpressive
    Sep 28, 2004
    81
    11
    Hemel Hempstead, Hertfordshire
    +7
    So sorry if this had been dealt with b4 :rolleyes:
    My sky+ remote control stopped working and when I opened it up, I found that one of the batteries had leaked into the compartment.
    I cleaned out the comartment with cotton wool and changed the batteries; this had the remote control working again, except that none of the "sky+ features " buttons worked anymore!
    Still working:
    Number buttons
    Red, green, yellow and blue buttons
    Channel + and - buttons
    Power Button
    Select Button
    All the other buttons do not work and do not even light up on the IR sensor when pressed.
    Can anyone tell me if/how this can be corrected, or is it time to get a new remote?
    Thanks.
  2. JayCee
    JayCee
    Jan 20, 2004
    20,335
    Lanarkshire
    +1,953
    The electrolyte leak from the batteries will have corroded a piece of the remote circuit board and/or components on it.
    If you are able to open it (small Torx screws) you could try cleaning it with Isopropyl Alcohol and a cloth.......if that doesn't work.....new one required.
