sky+ remote control code for relisys 1720?
Discussion in 'Sky Digital TV Forum' started by andycarmi, Feb 23, 2005.
  1. andycarmi
    andycarmi
    Hi all
    Can anyone help me with the sky remote code for the above tv????
    hopefully someone on here will be ble to help me out
    Andy :D
  2. Cynthia 7
    Cynthia 7
    Hi andycarmi,
    I understand this television is made by Orion. If that is the case then one of the following codes should work. Sorry it's such a long list, I hope you don't have to go through them all!
    322 383 263 205 039 065 053 348 349 392 544 054 130 037 502 239 584 297 345 471 505
    If it is an older digibox also try 0549 572.
    Good luck and plenty of patience!!!
  3. mdanforth
    mdanforth
    Feb 21, 2005
    193
    Cambridge
    +4
    None of them worked for me either!!
  4. Cynthia 7
    Cynthia 7
    Bad luck guys. I think the problem with the latest televisions is that the remotes do not have their codes in their memories. You could try the method on the satcure website of finding the code by the blink method, but again it will only work if the remote recognizes the code. This method is found before the manufacturers codes tables.
    Orion also make Admiral televisions, you could try their codes, also given on this site. The second code table is more likely if your sky digibox is fairly recent.
  5. Cynthia 7
    Cynthia 7
  6. selwonk
    selwonk
    Jul 30, 2005
    4
