Sky remote codes ?
Discussion in 'Home Cinema Control & Remote Controls' started by Grev, Feb 16, 2002.
  1. Grev
    Grev
    Does anyone know how I can program my original Pace Sky remote to control my Toshiba TV. When the sky installation engineer did the install I had a Sony TV, which the Sky remote could control. Now I've replaced the TV with a Tosh, it won't control volume etc.
  2. Spencem
    Spencem
    Oct 15, 2001
    197
    Northampton
    +9
    You need to reprogram the remote. If you have the manual for the Digi box the codes are in there, other wise give Sky a call. I would let you know the procedure, but I'm at work and my manual is not:clown:
  3. Grev
    Grev
    Thanks Spencem. I'm pretty sure the manual has walked. Can't remember ever reading it ! I'll try giving Sky a call
  4. sraper
    sraper
    Aug 7, 2001
    770
    Watford, UK
    +250
    This link msay help
