Sky remote codes not working
Discussion in 'Sky Digital TV Forum' started by softcell89, May 25, 2005.
  1. softcell89
    softcell89
    Hi i have recently put a Amstrad DRX100 im my room and i cant get any of the listed TV codes to work with my Schneider SVTV1451 14" portable TV. Does anyone know what code will work with this TV?
    Many Thanks
    Harry.
  2. Bluevanman
    Bluevanman
    Try these
    Schneider 0665: 065, 040, 351, 245, 246, 275, 399, 041, 287, 389, 422, 584, 572, 377, 380, 364, 331, 371, 547, 191
  3. softcell89
    softcell89
    Thanks Bluevanman but the codes dont want to work.
  4. Bluevanman
    Bluevanman
    Are you programming it correctly? The sequence is:
    Press tv,red and select together until the led flashes twice.Press tv again, enter the code and the led will flash twice again. Try switching the tv off. If it doesn't work,press TV again and then try to switch off.Keep stepping through like this. If the led flashes three times you have tried all the codes.
  5. Jaxxal
    Jaxxal
    The SVTV1451 (SVTV 1451 b) is the Schneider TV Video Combi, I believe?
    Try the Sky+ Remote Code for Orion (0549) as although the TV says Schneider it is actually an Orion Chassis (took me a while on Google to find that out).
    Not sure which it is exactly 0549 : 322, 383, 263, 205, 039, 065, 053, 348, 349, 392, 544, 054, 130, 037, 502, 239, 584, 297, 345, 471, 505, 207
    Hope that helps...
    Jaxxal.
  6. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
    Welcome to the forum and a helpful first post.:smashin:
    I only hope that the OP still has the TV after your 'grave digging':eek:
  7. Jaxxal
    Jaxxal
    lol, I only posted it because there was no answer to it anywhere on the net, and was hoping if anyone else had same problem they'd find my post too :D
