Sky remote codes for LG
N
nhaines
Has anyone got these codes for sky remotes-
LG RZ-37LZ31 (with sky hd)
LG RZ-15LA66 (normal sky)
tried all codes on sky interactive and satcure website
thanks
gilburton
try 0058 but if that doesn't work use the tv/on off button repeatedly until the tv switches off as per the sky instructions.Mine didn't work with the Sky+ but when I had HD installed this was the number suggested but I had to do the on/off procedure as well(just a couple of presses) and it worked.Great to have the volume back.
chipray
You may need a newer remote control. There have been other threads concerning the codes for recent LG LCD TVs. I could not get my Sky remote to work my LG RZ-26LZ55, yet an older JVC HDD/DVD recorder remote can operate the TV and the Sky box.
Another reason to stick with Sony TVs? :lesson:
FRANTIC FRANC
LG used to be goldstar so try that code. I've found that sometimes 0125 may work some tv's or try the 3 digit code method 065
Cheers, Franc
N
nhaines
how can i get newer than a sky hd remote control- 2 months old?
gilburton
I contacted LG and they gave me lots of codes to try but none worked until I got HD.The code 0058(which someone else suggested) did not work immediately on mine when I tried to set it up but I immediately followed it with the tv/on/off method and after a couple of presses the tv switched off and ,following the instructions,I locked it in and it has been working ever since.There are lots of threads about this problem with LG/Sky.
Similar threads
