Sky Remote codes for LG plasma?
Discussion in 'Home Cinema Control & Remote Controls' started by robyoung, Nov 20, 2003.
  1. robyoung
    robyoung
    Nov 9, 2003
    939
    Milton Keynes
    +65
    Anyone got them? ones i have dont seem to work!!
  2. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    I got mine to work on the LG14 in January but it was trial and effort. Can't remember what number worked sorry but it didn't take long so if you start low and go up you should find it.
    Good luck.
    Panic
  3. reggiewac
    reggiewac
    Nov 30, 2003
    26
    London
  4. robyoung
    robyoung
    Nov 9, 2003
    939
    Milton Keynes
    +65
    hi, thanks for the link.
    none of those seem to work either, so it could be that my remote is too old or my telly is too new! any one else with suggestions?
    thanks rob
