Hi All Anyone know the code for the Samaung F series tv's?
JayCee Distinguished Member Dec 10, 2006 #2 You'll maybe get a bit more response if you post the full model no.
K kit-kat Standard Member Dec 10, 2006 #3 JayCee said: You'll maybe get a bit more response if you post the full model no. Click to expand... Ok dok Samsung LE46F71B 46" LCD TV
F FRANTIC FRANC Established Member Dec 10, 2006 #4 kit-kat said: Ok dok Samsung LE46F71B 46" LCD TV Click to expand... If 0060 doesn't work on the new silver standard remote then try 0092 Cheers, Franc
K kit-kat Standard Member Dec 12, 2006 #5 FRANTIC FRANC said: If 0060 doesn't work on the new silver standard remote then try 0092 Cheers, Franc Click to expand... Cheers mate It was the 0060 code that did the trick! after rereading how to install the 4 digit codes!!!!!!!!
