Sky Remote code to operate Sony DB930 Amp ?
P
pete267
Evening All,
Is it possible to get my Sky+ remote to operate the volume on a Sony DB930 amp ?
Ta
Pete
P
pete267
Have tried all the Sony codes I can find but none seem to work
P
pete267
Anyone know if it's possible to control volume on a Sony DB930 amp with a sky+ remote
P
pete267
Thanks for the info, I tried 1086, 1186, 1286. The new sky+ remote I have didnt seem to accept 0186.
FRANTIC FRANC
Have you tried all the codes in the 0000 (the 4 digit code for Sony)? I have seen the Sky remote work Stereo tuners before (musch to the annoyance of the customer :D ). Soyou never know!
Cheers, Franc
P
pete267
Franc,
Sorry, I dont understand, ive tried every 3 digit Sony code I can find and the lists just list Sony 4 digit codes as 0000 ?????
Pete
FRANTIC FRANC
press:-
TV
red + select (untill the RCU blinks twice)
TV
0000
off
If the TV turns off press select. If the tv does not switch off then press tv again then off (repeat untill the TV turns off then press select)
Cheers, Franc
Similar threads
