Sky Remote Code for Samsung LE26R41BDX?
Discussion in 'LCD & LED LCD TVs' started by wafc, Aug 1, 2005.
  1. wafc
    wafc
    Jul 20, 2005
    689
    Wigan
    +45
    Does anyone know the Sky Digital (not sky+) Remote code for the Samsung LE26R41BDX?
    I have tried the main code in the Sky manual which is 0060 but although this does make the red LED on the tv's power switch flash when I press buttons on the sky remote, nothing happens!? Anyone else have this problem or know a code I can use to get this working?
    I have tried codes mentioned such as 0060, 0088, 646 but still cant get any to work!
    :lease:
  2. Fsheehan
    Fsheehan
    Sep 6, 2002
    444
    Up North!
    +8
    Hi mate,
    Sorry if it's off topic.
    Is this the one you ordered from Play.com? I ordered about the same time as you when it said in stock and now it's saying out now and will be delivered when stock arrives?
    I did ring them to ask them why they have not sent it yet when it was in stock and they told me that none had come in yet as it was a preorder?
  3. wafc
    wafc
    Jul 20, 2005
    689
    Wigan
    +45
    Yes mine is the one from Play.com, I had an email to say it was posted on Thursday or Friday last week and the tv arrived yesterday!
    Can anyone assist me with the Sky remote code? Given the fact that I've tried the codes which I posted above.
    Thanks.
  4. Doctor Hades
    Doctor Hades
    Jul 10, 2005
    3,258
    East Yorkshire
    +305
    Not much help I know but I got my remote to kind of work using the three key code, 318. However, pressing Standby on the Sky remote just switches the video source but it's still an improvement on what happened before, i.e. nothing!
  5. paul156
    paul156
    I got my Samsung LE32R41BDX to work off a SKY Digibox Remote
    (NOT SKY PLUS) With the 3 digit code 088.
    (After trying LOADS OF CODES)
  6. carpman
    carpman
  7. ukhm
    ukhm
    Guys,
    I have spent 45 mins on hold waiting to get the code for the Samsung LE32R41BDX.
    Here are the instructions
    Clear the memory by pressing TV
    Press Select and Red until your remote light blinks twice
    Type in 999
    Press Select
    Then TV
    Samung LCD LE32R41BDX Remote Code
    Hold the Sky remote away from the TV and press TV
    Type in 672
    Press Select
    Then TV
    Then Sky
    Try the volume, mute and Power
    It worked for me...
    Hope it helps you guys!! :thumbsup:
  8. GazzaBloom
    GazzaBloom
    Oct 11, 2005
    72
    +4
    Who did you spend 45 minutes on hold with? I called Sky and they said they do not have the Samsung LCD codes yet...
    I have tried repeatedly your method and cannot get 672 to work on my old blue Sky remote. 088 doesn't work either. I can get the red led to flash as "wafc" suggested in his original request but nothing beyond that.
    Gazza
  9. Doctor Hades
    Doctor Hades
    Jul 10, 2005
    3,258
    East Yorkshire
    +305
    Nor can I although 292 causes the LED on the front of the TV to react when I press buttons on the Sky Remote. Sadly it doesn't do anything though. :(
    Even using the method where the remote flashes the number back at you by pressing 1 (gives me no flashes), 2 (gives me three flashes) and then 3 (gives me eight flashes) on the remote doesn't work either and 038 definitely doesn't work.
    Oddly 038 isn't listed on Sky Technical Help page but 037 is. However I've repeated the process several times and the remote definitely flashes eight times for the third number.
    I've given up trying to get this thing to work now. :thumbsdow
  10. SquadMonkey
    SquadMonkey
    Can't get the code sequence above to work for my Samsung LE23R41BDX either.
    Could it be down to different remotes?? - Sky must of made some revisions over the years. I'll have look, but if anyone else finds something then please post.
    Best,
    Rob.
  11. SquadMonkey
    SquadMonkey
    I've just tried the 4 digit code for the Samsung - 0060. If it's correct then it will flash twice, but it won't for my TV!.
    Totally at a loss now! - it has to be down to different versions of the remote.
  12. GazzaBloom
    GazzaBloom
    Oct 11, 2005
    72
    +4
    Not much to add, but I can tell you that I just got my old Panasonic DMR-E30 DVD Recorder remote to work the Samsung LE32R41BD (volume, channel change etc) using a code in the Panasonic's manual = 43.
    Now if only Sky could catch up and get it sorted...
    Gazza
  13. GazzaBloom
    GazzaBloom
    Oct 11, 2005
    72
    +4
    Don't give up Doc... :hiya:
  14. acemelhaz
    acemelhaz
    Jul 21, 2005
    194
    portsmouth
    +13
    hi the code 672 works on my sky +
  15. Max Reboh
    Max Reboh
    Jun 11, 2005
    29
    3
    Thanks Paul that worked for me on a non sky + box
    Regards
    Max
  16. jockysplit
    jockysplit
    Sep 11, 2005
    3
    Thanks, I'm happy as my girlfriend kept moaning because the sky remote didnt turn the volume up or down.
  17. Ljays
    Ljays
    I fancy one of those Samsungs are they any good for games? also whats the difference between LE26R41BDX and the LE26R41B other than price? Heres a link
    http://play.com/play247.asp?pa=search&searchtype=allproducts&searchstring=samsung&page=search
  18. Thebatfink
    Thebatfink
    Nov 20, 2005
    68
    Notts
    UKHM code worked for me, (Power / Mute / Volume) on my sky plus box.
    Thanks!
    LJays -
    Ive just brought the B from play. LE32R41BD or LE32R41B are the same. The LE32R41BDX is the same TV again, but with a freeview tuner built in. If you have sky, save yourself 50 notes and dont bother with the freeview :)
  19. McChubby
    McChubby
    Jun 7, 2005
    159
    16
    Portsmouth
    No, your reply is incorrect:
    The BD and BDX models are identical (they are actually the same model, it is just the way some retailers quote the model number) - this is the model with the internal freeview tuner.
    The B and BX models only have a "regular" analogue tuner.
  20. Thebatfink
    Thebatfink
    Nov 20, 2005
    68
    Notts
    Ok, I miss spelt the model numbers :/ The two models on plays are different only as one includes freeview like I said. But thanks to McChubby for his clearing up on the model number.
  21. wungie
    wungie
    Nov 27, 2005
    11
    3
    thanks ukhm, the 672 code worked superbly on my le32r41bdx.
  22. GazzaBloom
    GazzaBloom
    Oct 11, 2005
    72
    +4
    Nope...088 & 672 do not work for me - Sky Digital (not +)!
    Gazza
  23. Drunken Master
    Drunken Master
    May 12, 2001
    836
    In the middle of a roundabout
    +7
    The 088 code worked on my Sky remote (not sky+) and LE26R41BD
  24. boyimace
    boyimace
    Jul 3, 2005
    398
    +5
    I got it to work on my new Sammy LE32M51, cheers!
    :smashin:
  25. simon555
    simon555
    Jan 3, 2006
    156
    Milton Keynes
    +10
    672 worked on my 26", thanks
    Simon
  26. J-K
    J-K
    Feb 25, 2005
    141
    London
    +3
    Are you trying it just as 672, or as 0672? 0672 is whar worked for me - and should work for you too!
  27. discodevil
    discodevil
    Sep 10, 2004
    22
    4
    Sheffield
    I tried this code for my Samsung LE26R41BD and it worked a treat. Many thanks
  28. ben_e71
    ben_e71
    Jan 21, 2003
    200
    Gnometown
    +6
    Defo works on my LE2341BDX but had new revision normal sky remote so added 0 then 672
  29. TitanUK
    TitanUK
    Feb 13, 2006
    4
    London
    Well having just tried about 15 codes while on the phone to Sky in the end they tell me that I need a new Sky remote as mine is old....!
    Not sure about that but perhaps will give it a go.
  30. carex
    carex
    Mar 29, 2005
    55
    9
    Don't think it's been mentioned, but 646 worked for me
