Sky remote code for samsung LCD
Discussion in 'LCD & LED LCD TVs' started by timanfiya, Dec 1, 2004.
  1. timanfiya
    timanfiya
    Anyone know the sky remote control code for this samsung 14" lcd. (LW15M13C) or know where I might be able to find the code. Sky just say they don't have this model listed and none of the codes on interactive under samsung work.
    Any ideas. :lease:
    Cheers.
  2. Steve236
    Steve236
    I have the same problem with my 20in Samsung LCD
  3. timanfiya
    timanfiya
    Its actually for a friend of mine, hes been trying to get a code for a while now. I found a method to find the code on the internet but don't know as yet if it worked for him.
    You could also give this a try if you still need a code:
    1) press tv on remote and face towads tv
    2) Hold red button and select until led flashes twice
    3) Key in 990
    4) Press number 1 and watch how many times it flashes if it does not flash this means your first digit is 0 if it flashes five times then your first digit is 5 and so on.
    5) When it finishes flashing note your first number and press digit 2 and note how many flashes then 3 and 4 (incases your remote uses a four digit code and not a three - if on the fourth digit it does not flash I suppose this could either mean you only have a three digit code or your fourth digit is a zero.
    6) Follow the normal procedure to input a code and give it a try.
    Let me know if it works for you. It works on my own tv but i already had the code for that anyway. :thumbsup:
  4. Steve236
    Steve236
    Nah, didn't work for me, Gave me 0292 whatever TV I pointed the remote at.
    Found the code for my Samsung though elsewhere - it's 0088.
  5. timanfiya
    timanfiya
    Where did you find the code? the blinks didn't work for my mate either??
