Sky remote code for sagem HD45
M
merlin200sx
hi iv just had sky fitted and i cant find a code for my sagem HD45 tv in the guide book
can any one help with the program code so that i can chage to volume form the sky remote ??
:thumbsup:
nat695
:hiya: Hi,:hiya:
I just placed an order for the 50" Sagem:clap: .
:lease: Has anyone out there found the remote code for Sky yet? :lease:
ruthiebabie
Hi - this might help (or not). I couldnt find the code for my tv either on the customer services site therefore I got as far as selecting the make and then just started trying some of the codes connected with my make - 4 codes into the list and bingo it started working. Worth a try if you've got a bit of time spare.
JayCee
Which is what you're supposed to do...:confused:
JayCee
ruthiebabie said:
No - it has model numbers as well except my model number wasn't listed therefore I just picked codes at random
That's still what you're supposed to do...try all the codes for your TV set brand.
SamRadford
Which revision remote have you got? I suspect that only a Rev6 remote will have the code.
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
