Sky+ remote code for Pio 43 XDE Plasma?
Discussion in 'Sky Digital TV Forum' started by J-K, May 5, 2005.
  1. J-K
    J-K
    Feb 25, 2005
    141
    London
    +4
    Hey people,
    Does anyone happen to know the Sky+ remote control codes for the Pioneer 435 XDE plasma tv?
    Any idea where I can find it?
    Cheers,
    JK
  2. Cynthia 7
    Cynthia 7
    Hi J-K,
    At the top of the forum page on the blue banner click on "Search". Type markhawk in the box that appears there. Two posts will appear. Click on the post "Pio 435 Sky+ Remote Code. Read the whole thread and you will see a website mentioned. This should help and the codes quoted in the thread by other members.
    If you have an old Sky+ Remote (prior to Rev 4) it may not be programmed with codes for the latest television and therefore wouldn't work. Argos sell the Rev 5 version and you can buy version 6 online. You can check on which Rev you have by looking inside the battery compartment, there is a little sticker in there. If it doesn't work it may be time for a new remote! Good luck!
