SKY Remote code for Logik LCD ????
Discussion in 'Home Cinema Control & Remote Controls' started by elmbeck, Feb 13, 2005.
  1. elmbeck
    elmbeck
    Sep 23, 2002
    347
    Avonbridge
    +10
    Model LCX14LN1.
    Codes required for SKY+ remote.... all SKY can suggest is 221, 033, 061, 039 and 726.
    None of these work. ANY IDEAS ??
    Cheers!
  2. tombrown
    tombrown
    Mar 27, 2005
    14
    Bump?! Could do with this code too!
  3. Drogo
    Drogo
    Dec 13, 2003
    289
    English Riviera
    Same here, have tried but nothing ...
  4. Cynthia 7
    Cynthia 7
    Hi guys,
    fozzy 73 posted this last June on this forum.
    "There is no specific code for a logik tv for Sky remote to work to. Try the blink back feature on the following site. It's near the bottom of the page".
    Someone had success with this method recently with a new unfamiliar name plasma. You have to be very patient with this. I did see one code given to someone to try but I don't know whether he tried it for his Logik. It was 0016.
    http://www.satcure.co.uk/tech/digicode.htm
    Good luck!
  5. Cynthia 7
    Cynthia 7
    Hi elmbeck,
    On the lcd television forum phanco had tried to find new codes for his Beko tv. He had tried all the codes given to him.
    He has just bought a more up to date remote from Argos for £25, which is Rev5 version. (You can get the latest Sky+ Rev6 version by going to http://www.letsautomate.com Then click on Sky+ remote in their Best Sellers List. It's less than £15 inc. vat but you do have to pay postage). Now, he has found those codes work and his new remote controls his tv perfectly. Check your Rev version by looking inside the battery compartment. If there isn't one there then it's a really old one. Hopefully your tv is programmed into these new remotes.
    It would be worth getting the latest remote to see if it will operate your Logik with the codes given on Sky interactive, maybe these are the ones you have.
