Sky remote code for LG RZ-32LZ50
Discussion in 'Sky Digital TV Forum' started by m_stan, Oct 5, 2005.
  1. m_stan
    m_stan
    Can anyone help me out by providing a Sky remote code for my LG RZ-32LZ50 ? Haven't been able to find one online and Sky's Interactive help does not include this model number.
    thanks
  2. JayCee
    JayCee
    Jan 20, 2004
    20,057
    Lanarkshire
    +1,912
    Did you try all the LG codes on the Help menu?
  3. m_stan
    m_stan
    yes, and unless I'm doing something wrong (always possible), non worked
  4. m_stan
    m_stan
    Non of the codes on the Sky Interactive Help menu worked.
    Does anyone have any suggestions ? Please ? I'm sick of using two remotes !
  5. JayCee
    JayCee
    Jan 20, 2004
    20,057
    Lanarkshire
    +1,912
    Use the manual search method as detailed in the Sky user manual and you will probably get a code.
  6. m_stan
    m_stan
    I cant find any reference to the manual search method in my sky manual.
    Can you please explain ?
  7. JayCee
    JayCee
    Jan 20, 2004
    20,057
    Lanarkshire
    +1,912
    Do you have Sky or Sky+?
  8. m_stan
    m_stan
    Plain ole Sky
  9. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    I've got the LZ50, I've never found a code for it, or any other code for any LG TV that I have supplied, or worked with. Pain in the .....
  10. m_stan
    m_stan
    ok thanks. A guy on another board mentioned that a 28" LG tv he has is the same but each button can be individually programmed to do what you want. When he posts the instructions I'll post them here.
    How do you find this set anyway ?
    I'm pretty happy with mine.
  11. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    I use it as a PC monitor, it's fine for that, and has the widest signal acceptance of any LCD TV I've ever come across. Unfortunately, the picture is totally crass, I've never seen worse on any display, any time. Colour bleed, and leary, over bright, over sharp images on scart, it's truly shocking.
