Sky remote and denon 3803
G
gpa
have done quite a lot of serching for the remote code to operate my denon's volume via the sky remote, however have not been able to find anything, can this be done and if so anyone have the correct codes.
cheers
chris
Dont think it can be done, as the remote is for controlling the volume and basic buttons of a TV and seeing as Denon do not make TV's, i would not see the point of putting a code out.
Contar
Why don't you program the Denon remote with the sky functions?
This is how I have my 3802's remote set.
mick23
contar
how did you manage to get the denons remote to control skybox i have the 3802 and hk507 neither contain codes for the original pace sky digibox , the pace remote sky uses a differant protocol, even the marantz 500 i think its called a do it all remote costs £98 cannot operate a skybox without a special red eye senser,
ps i see you have panasonic sky box not pace digibox my error
mw3cdj
mw3cdj
Can't remember which code i used, think it was 0188:confused: .
Don't forget to do the VOLUME/MUTE CONTROL PUNCH THRU . It saves you having you press TV first . You can change the volume with the remote still in sky mode ( Very handy;) ).
Regards,
Daran.
G
gpa
God thanks for all the replys guy and gals I'm off to give it a go, will let you know if it works.
cheers
Contar
I am sure when I programmed my Denon remote it is a learning remote. I will have to dig out the manual.
itcosthowmuch
Yep Contar you are right. The Denon's remote learns the sky codes (and any others come to that!). I've got mine running all the basic controls on sky...works a dream, when you can remember to pick the 3803's remote up the right way :rolleyes:
M
mick23
hi all spent sometime yesterday using 3802 remote to use with pace/sky digibox and another sat-reciever finally got the "gist"of how to use 3802s learning function and am pleased to say that denons remote controls most of the functions of my
tv/sky-digibox-vcr-sat-reciever , i now am using 3802 remote rather than six seperate ones,
J
jmack
can confirm this does work . just done mine.strangel thing, if you dont do the punch through the up and down arrows control the amps volume instead of the volume button,
do the punch through and you can control volume in sky mode.:D :D
if only i could get it to turn plasma off aswell(can this be done)i would get rid of pronto
mw3cdj
jmack,
You can get it to turn your plasm off ;) . First programe it to control the plasma, and then do the "HUMMER" bit. When you press TV and off/on your plasma will turn on or off :D :D .
This works on my hitachi.
Regards,
Daran.
J
jmack
cheers whats the hummer bit?
so i do plasma code first?
then i do the denon code?
yes
anyone know what the panasonic plasma or toshiba if they the same ?
mw3cdj
mw3cdj
I think the Toshiba code is 0156 ahd the panasonic is 0051.
Regards,
Daran
G
gpa
Well gotit working as such but not right, looking for codes that control volume correctly.
cheers
J
jmack
ive allready entered the denon codes. will it matter if i enter panny/tosh ones now
mw3cdj
J
jmack
how will i know its worked ? is it a case of pressing tv and then press every button to see if plasma goes off/on
in sky mode or tv mode
do i press tv twice to cycle through to plasma or will it do it on the same page as amp buttons(remote not page)
mw3cdj
You will know if it has workes by pressing TV and then the OFF button. If your plasma goes of it's worked.
mw3cdj
Jmack,
just noticed you live in cardiff, i live just outside Swansea. Have you had any dealings with 7 oaks in Cardiff ,if so what's they service like ??
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
Trending threads
Latest News
MBL brings high end Hi-Fi systems and speakers to UK
  • By Andy Bassett
  • Published
Roku announces Streambar and adds Airplay to streaming devices
  • By Andy Bassett
  • Published
Amazon Prime Day confirmed as 13-14th October
  • By Andy Bassett
  • Published
Linn upgrades Majik LP12 turntable with new tonearm
  • By Andy Bassett
  • Published
VPI announces new Prime 21 turntables
  • By Andy Bassett
  • Published
